98 Blazer to 87 s10 rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 04:09 PM
i have been told that a 98 blazer rear diff will bolt up to my 87 s10 truck. any ideas as to if this is so??? im wanting to convert to rear disc brakes. this is the reason for the swap
Old 04-04-2013, 04:22 PM
RWENUTS's Avatar
Blazer rear is too wide. It's 58". S10 is 54" for 2wd.
If the S10 is 4wd it's the same. Blazer ZR2 is wider yet at 62".
Old 04-04-2013, 07:41 PM
big gear head's Avatar
High Performance Rear Ends
If both are 2 wheel drive or 4 wheel drive then it will swap. You can bolt in a 4 wheel drive rear end into a 2 wheel drive truck, but the wheels are going to stick out a bunch. Just be sure that they are both the same and it will be fine.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-04-2013)
Old 04-05-2013, 06:58 AM
thank to all for the helpful advice, that lets me know the directon i need to go.
s10 rear end swap rwa1015 Transmission - Rearend 12 11-22-2010 07:38 PM
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 09:44 PM
rear-end ratio for s10 blazer chrismac Transmission - Rearend 2 07-21-2007 11:05 AM
S10 700R4 to 76 Blazer swap Drewnashty Transmission - Rearend 6 06-12-2006 10:30 PM
