-   -   98 blazer "clicking" noise (http://www.hotrodders.com/forum/98-blazer-clicking-noise-108812.html)
smspikesm 02-11-2007 08:43 AM
Hello all,
There is a "clicking" noise coming from the front end (right side)when moving. It speeds up with acceleration. When 4x4 is engaged, the noise stops. Also, when 4x4 is dis-engaged, the noise briefly stops for about 5 seconds. The clicking also stops when in reverse. Any info on what this noise might be?
Much respect,
Chris
Crosley 02-11-2007 05:07 PM
Originally Posted by smspikesm
Hello all,
Much respect,
Chris
steering knuckle ? U-joint? Wheel bearing?
poncho62 02-11-2007 06:13 PM
s10 Blazer? CV joint......Front diff clutch may be partially engaging.
