98 blazer shifts hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 03:13 PM
Had my trans flushed now it shofts hard any ideas
Old 07-03-2005, 05:55 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
We need more info. What type of trans flush did you get? Was it the drop the pan and replace 5 qst of fluid and filter, or was it the good type that flushes the complete system with 16 qts of fluid? Did you have ANY problems before you had the flush done? If so what? How many miles on the Blazer?
Steve
Old 07-03-2005, 06:24 PM
poncho62's Avatar
Wiki Edits: 5
moving this to tranny forum, where it belongs........
Old 07-06-2005, 05:40 AM
Steve
I had a full flush 16 quart ond had no problems before that the tranny is only four month old and still under G.M. warrenty but if theres something I can do to clear it up I would rather do that then put it in the dealer. I also get no error codes. Any ideas?
Old 07-06-2005, 08:03 AM
1931 steve's Avatar
Wiki Edits: 4
Take it back to the dealer, I know that dropping your car off at the dealer for at least a week is no good, but if you do anything they(the dealer) can void your warranty. It could be as simple as an connector problem or calibration problem, also could be a hard part. Let the dealer make this call. Ask for a loaner car since you just had it replaced. Also did the dealer do the trans flush for you?
Old 07-06-2005, 05:27 PM
Yes the dealer did the flush. I kind of figured I'd have to take it back to the dealer, but I didn't want to. I use the car to deliver mail and it's been pretty dependable, but lately it's been a real headache. this month it seems like everything is going wrong. I do all my own work on it but I don't know anything about transmissions. This month I've replaced upper and lower ball joints, right hub, upper control arm bushing, rear wiper motor, and today I noticed my rear end pinion shaft seal is leaking. It's been a rough month, but still cheaper to fix it myself rather then buy another. It realy gets abused on the mail route. Anyway thanks for your help.
98 Blazer Shifting Hard After Long Trip Ghetto Jet Transmission - Rearend 5 06-28-2005 08:41 PM
98 blazer wont start then fires right up jum Engine 2 10-16-2003 03:12 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
98 Chevy Blazer Overheating sgrobb Engine 1 07-23-2003 03:02 AM
shifts hard mikeh Transmission - Rearend 3 12-04-2002 07:26 PM
