98 blazer wont start then fires right up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2003, 02:49 PM
jum jum is offline
drove 98 blazer with 4.3 engine to work, and it ran fine. 8 hours later it would just turn over (engine) and would not start. This morning got in it and it fired right up. Drove it to the nearest computer and had it running on there for 25 minutes and found nothing wrong. Any suggestions? as always thank you for your time and help. Jum
Old 10-16-2003, 03:01 PM
kellogs's Avatar
check for fuel pump related problems.low pressure or bad rely.these will not leave codes.
Old 10-16-2003, 03:12 PM
roys63's Avatar
Check in fuel system as said above and the coil wire and the rotor they will burn through and check the Resistance of the coil.
