98 camaro v6 to an old skool v8 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2010, 07:00 PM
98 camaro v6 to an old skool v8 swap? I'v been thinkin about this since i bought the car, and am wondering if a carberated v8 will bolt up to the 5spd trans thats in the car? I know i will have to make engine mounts, and posibly install a cowl hood so it will fit, and a lowpro dist. but has anyone else tried this kind of a swap yet? they came with a v8 option, but they seam like totally diff engines? there's lots of room so i think i can do it!? I'm just sick of the new fuel injected engines that dont put out like the old sb's do!
Old 11-30-2010, 07:12 PM
bigdog7373's Avatar
Of course it's fast
It will work as long as you upgrade your fueling system, cooling system, front suspension, exhaust, rear diff, transmission, and get new accessories to fit it.
Old 11-30-2010, 09:54 PM
98 camaro v6 to v8 swap
does anyone know if the bell housing for the 5spd trans from a v6 3.8l will bolt up to a old sbc 350 everything else i know needs upgrading, fuel psi reg, suspension, exhaust, all that but the only thing that is givin me doubt is the trans. i really dont want an at in this car. i do have a 4spd i could put in it, but still want the drivability with the OD 5spd. thanks for the info!
Old 11-30-2010, 10:12 PM
bigdog7373's Avatar
Of course it's fast
yes. the V6 is basically an sbc with 2 cylinders chopped off.
Old 12-04-2010, 06:52 AM
Not in a 98 Camaro. That's a Series II Buick V6 that uses the 60 degree metric bolt pattern. The bellhousing will NOT bolt up to any V8. The Chevy V8 was factory offered, you will need to source a parts car. Of course, if you have emissions testing where you live, this swap will not pass. You would need to swap all the parts from a 98 or newer Camaro, and just buying a V8 car would be cheaper. Besides, why do you want a carb engine? The injected motor makes more power.
4.3 v6 93 cpi or 98 scpi , easier swap smog wise? jamess Engine 1 10-29-2010 10:17 PM
v8 engine swap in 68 firebird FIREBIRDTONY Engine 17 02-07-2008 09:48 PM
help with v6 to v8 swap bigt6599 Engine 7 09-27-2003 02:39 PM
Convert From V6 to V8 in 86 camaro??? 1986 Camaro Engine 4 10-14-2002 01:29 PM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 04:58 PM
