Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '98 cherokee frnt differention popping noise
  #19 (permalink)
Old 07-26-2009, 11:09 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
There is no C-Clips on that diff.
Remove diff cover to drain oil
Remove tire
Remove Brake caliper
If it's the 1 piece wheel brg set up,Look in the back of the knuckle,and you will see 3 or 4 bolts holding the whl brg assy in. remove those
Remove the whole axle assy as 1 piece.
When installing the axle, BE EASY sliding the axle assy in ! You want to be careful not to mess up the inner axle seal.
