Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '98 cherokee frnt differention popping noise
  #20 (permalink)
Old 07-26-2009, 11:18 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
You can change the joint with the whl brg assy still on the outer axle. I will normally leave the whl brg on the outer axle. Sometime's the nut will pull the threads on the outer axle on removal even after being sprayed down with WD.
