Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '98 cherokee frnt differention popping noise
  #21 (permalink)
Old 07-26-2009, 12:32 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by prostreet6t9
There is no C-Clips on that diff.
Remove diff cover to drain oil
Remove tire
Remove Brake caliper
If it's the 1 piece wheel brg set up,Look in the back of the knuckle,and you will see 3 or 4 bolts holding the whl brg assy in. remove those
Remove the whole axle assy as 1 piece.
When installing the axle, BE EASY sliding the axle assy in ! You want to be careful not to mess up the inner axle seal.
Must make for a heavy assembly to handle. I have never done one that way.
Also when removing the axle nut, white lithium grease will keep the threads from galling.
WD-40 is not a good lubricant at all, especially in this type of application
If it has abs be careful not to break any wires
Chet
