Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '98 cherokee frnt differention popping noise
  #23 (permalink)
Old 07-26-2009, 05:54 PM
newdad1 newdad1 is offline
Yep, I have the one piece wheel bearing set up with 3 bolts holding the whole assemble in. Can I use a 12 point socket to take those 3 bolts off? I assume the inner axle seal is the seal that keeps the gear oil in the differential itself and keeps the gear oil from trickling down the axle towards the wheel?
Ok, thanks again guys. I will get started on this tuesday morning.
