Originally Posted by newdad1
Yep, I have the one piece wheel bearing set up with 3 bolts holding the whole assemble in. Can I use a 12 point socket to take those 3 bolts off? I assume the inner axle seal is the seal that keeps the gear oil in the differential itself and keeps the gear oil from trickling down the axle towards the wheel?
Ok, thanks again guys. I will get started on this tuesday morning.
12 point socket will work fine. And yes that is the seal. The only reason I suggest you pull the front cover is, If the diff is full of oil and you pull the axle out, the 90wt will run into the tube. After you install everything you will see some oil leakage from the axle tube till it's all gone.
You don't have to,It just make's it a little cleaner when your all done.
