Originally Posted by newdad1
It looks like the one piece hub/bearing assembly is making the popping noise. Where about should I apply wheel bearing grease on the new hub/bearing assembly? I'm going to replace the universal joint also, just to be safe. Do I have to apply the high temp wheel bearing grease anywhere else? And if so how much?
If it is the regular sealed bearing assy, there is no grease required. We sometime put a little lube on the axel splines to help them slide into the bearing but once the nut is tight nothing can move.
The bearings usually make a whining noise when bad. I dont think I have ever heard one pop but there is always a first time
