If you checked with it on stands it won't always pop it that position. It really needs the weight of the jeep all on the ground, Take it and a friend to a big parking lot get out let the friend turn the wheel and slowly move the jeep forward till it pops while you are watching and try reverse also this will help you in knowing what it might be if you can see it when it happens. Hope this helps. Cole
Depending on what style you have the details of the procedure is a little different. The overview, is you need to get the axle disconnected from the bearing assy, usually a large nut or with automatic hubs a few lock nuts and snap rings. I Usually split at least 1 ball joint and pull the spindle off and away from the axle, sometime splitting the tie rod off the spindle will help get it out of the way.
If it is a setup like a regular car, sometimes you can just unbolt the bearing and slide the axle out. Slide out the axle and change the joint(s). Make sure the grease fitting is accessible when it is re-installed When you are done the joint should move a little stiff but be smooth.
Artificial Intelligence is no match for Natural Stupidity Chet |
There is no C-Clips on that diff.
Remove diff cover to drain oil Remove tire Remove Brake caliper If it's the 1 piece wheel brg set up,Look in the back of the knuckle,and you will see 3 or 4 bolts holding the whl brg assy in. remove those Remove the whole axle assy as 1 piece. When installing the axle, BE EASY sliding the axle assy in ! You want to be careful not to mess up the inner axle seal. Last edited by prostreet6t9; 07-26-2009 at 11:22 AM. |
You can change the joint with the whl brg assy still on the outer axle. I will normally leave the whl brg on the outer axle. Sometime's the nut will pull the threads on the outer axle on removal even after being sprayed down with WD.
Also when removing the axle nut, white lithium grease will keep the threads from galling. WD-40 is not a good lubricant at all, especially in this type of application If it has abs be careful not to break any wires .
I was just using WD as a example. It may come off good,but you would be suprised how many outer axle stubs I sell for fords and jeeps because the threads get messed up when nut is removed. |
Yep, I have the one piece wheel bearing set up with 3 bolts holding the whole assemble in. Can I use a 12 point socket to take those 3 bolts off? I assume the inner axle seal is the seal that keeps the gear oil in the differential itself and keeps the gear oil from trickling down the axle towards the wheel?
Ok, thanks again guys. I will get started on this tuesday morning.
You will either want to drain the diff or put a bucket under it to catch any leakage. I usually do the bucket method but you can drain it, I dont think it is needed though and just causes more work. If you do decide to drian it make sure you get a new gasket.
You don't have to,It just make's it a little cleaner when your all done. |
It looks like the one piece hub/bearing assembly is making the popping noise. Where about should I apply wheel bearing grease on the new hub/bearing assembly? I'm going to replace the universal joint also, just to be safe. Do I have to apply the high temp wheel bearing grease anywhere else? And if so how much?
The bearings usually make a whining noise when bad. I dont think I have ever heard one pop but there is always a first time
Well, I finally finished the job. It never fails in that the auto parts store sold me a universal joint that was two small. Of course I did not find this out until I had everything apart. Other than that, everything went smooth. I took the entire axle/shaft/hub/bearing assembly out at one time. Chet, you were right, the bearing/hub assembly was fine, only the universal joint was bad. The directions you guys gave were right on the money.
I figure one of the true values of this website is this; The dealer wanted $202.00 just for the labor to do the job. Another auto repair shop wanted $370.00 to replace the whole axle/shaft assembly. Yes, my time is worth something, but let me say it feels good to keep that money in my pocket instead of handing it to someone else, particularly when I can do the job myself. Once again, many thanks to everyone for all the help. Robert D.
If you are one who changes your own oil, don't forget to grease that joint. So few vehicles have grease fittings now that most people forget that grease is still needed in universals on a lot of vehicles.
Glad it all worked out for you.
| 1991 Chevy truck AC/vent type popping noise | flyin99 | Electrical | 6 | 07-19-2007 06:39 PM |
| 98 blazer "clicking" noise | smspikesm | Transmission - Rearend | 2 | 02-11-2007 05:13 PM |
| popping noise | capn_crunch4x4 | Transmission - Rearend | 1 | 05-19-2006 12:30 PM |
| popping noise... | 97Z28 | Suspension - Brakes - Steering | 8 | 02-20-2006 04:05 PM |
| Overefficient cooling system and popping noise. | TVR383 | Engine | 8 | 11-09-2005 08:17 PM |
