98 Chrysler Sebring V-6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2010, 04:23 PM
Just acquired a Sebring w/ 2.5 V-6 to put in my 28 Model A. Just to be sure everything started out good I replaced the timing belt, car, rotor wires and fuel punp.
My problem is that when it is cold it runs good but when it gets hot it stumbles all over itself when you jab the gas. If you ease into the gas in neutral its fine as long as you don't stomp on it. Put it under a load in gear and forget about it.
What do you guys think? I don't want to pull the engine package until everything is running good. The computer throws no codes.
Jerry
Old 05-09-2010, 08:45 PM
sqzbox's Avatar
My pipes are my music
Could be the O-2 sensor or clogged cat.
Old 05-11-2010, 04:19 PM
98 Sebring
Found the problem. The coil was arcing in the distributor. Put in a new coil and it runs as sweet as can be.
Thanks for hekp.
Chrysler Sebring Bucket Seats Wiring 59 wagon man Interior 3 05-24-2009 06:52 PM
Intro - Old Guy Wants Chrysler Sebring Info PAUL ROSER Introduce Yourself 1 04-27-2007 11:50 AM
Chrysler Sebring PAUL ROSER Introduce Yourself 1 04-26-2007 10:30 PM
98 chrysler 2.5 v/6 swvalcon Hotrodders' Lounge 3 12-06-2006 11:41 AM
What is wrong with a chrysler 68newport383 Body - Exterior 23 02-11-2003 04:35 AM
