98 dodge intrepid major problems any dodge techs here? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-14-2013, 11:58 PM
Project89's Avatar
ok lobg story short past 2 weeks have been really cold so ive had a hard time starting the car in the mornings.
so far thats been my only issue until today
today im driving home from work and all the sudden the transmission downshifts and the gear selector indicator starts lighting up and flashing, 2 seconds later all my gauges went out,
tach,speedo,water temp,fuel level gauge , all the transmission indicator lights went out as well no check engine light
gauges do still light up though.
car still starts and runs normally and can be driven but transmission will not shift into over drive, normally even with the gear selector in 3rd (d) at 40mph at part throttle the trans will stll upshift on its own . it will not do this , it just never goes into over drive
u guys have any ideas on things to check
its been -10*f or less here the past few nights so im hoping maybe the really cold weather is screwing with something.
i can live without the over drive for now but i really need a fuel level gauge since even the odometer dont work without the speedo working
it will be another 4 weeks before i get my silverado 2500 back so i dont have another viechal to drive in the meantime.
i could drive my twin turbo camaro but driving that on ice/snow covered roads is not something i really want to do, besides the fact id have to reinstall the heater core/heater box , and other heating system components in the car before hand
Old 01-15-2013, 08:42 AM
Project89's Avatar
anyone got any ideas on stuff i can start checking i have a few hours before i head to work, and id like to start checking some things since by the time i get out of work the sun is going down and the temps are dropping and i have to work outside in the snow
Old 01-15-2013, 04:45 PM
LATECH's Avatar
Start by checking ALL the fuses. Under the dash and under the hood.
If they all check out...then you will need to run a scanner on it to see what codes are stored and in which modules.
For instance ...if the PCM says it has a communication problem with the transmission control module, and the Instrument panel cluster also has a similar code....then it would be wise to scrutinize the Transmission control module.
The speed sensors in the trans are important, but what it really sounds like is a fried trans module and or a fried IPC module.
These newer cars need a good battery. Jump starting them and running the battery dead, running off the little bit of charge the alternator provides for a dead battery will wreak havoc on electronic devices.
I would be shocked if a module or two wasnt fried.
All the jumping /charging /running the starter till battery is dead and such causes low voltage , voltage spikes, current surges and all kinds of stuff that cooks electronics.
Those cars are known to start hard due to bad/fouled spark plugs.
I have personnaly seen it here in the snowbelt of northeast Pennsylvania.
Fact is stranger than Fiction
Old 01-15-2013, 05:46 PM
Project89's Avatar
the cluster fuse was poped (5A fuse) replaced it and everything worked again made it about 10 miles and it went out again , so i must have a short somewere in the cluster circut.
im trying to find some wiring diagrams so i can start tracing wires, i just dont understand why if the cluster goes out the trans wont shift right or into over drive
Old 01-15-2013, 06:57 PM
LATECH's Avatar
IIRC the speedo processes the speed signal for the trans control module. When the speedo goes out, the trans go into "limp" mode
Old 01-15-2013, 08:52 PM
Project89's Avatar
ahh thanks im used to the gm stuff were the vss is fed into a buffer box with an output for the ecm and a seperate output for the speedo
i think i found the short in the dimmer switch , i replaced the fuse again and as i was pulling the headlight/foglight/dimmer switch assembly out of the dash it popped the fuse again, ran out of daylight but tommorow i will check for burnt wires , and use my multimetter to check for a short on the dimmer switch
i also found out the previous owner of the car had removed the cluster and pulled the check engine light bulb out ,only reason i found it is i had a few of the cluster lights out so i was checking all the bulbs to replace them
Old 01-16-2013, 04:32 PM
LATECH's Avatar
[QUOTE=Project89;1635315]
i also found out the previous owner of the car had removed the cluster and pulled the check engine light bulb out [QUOTE]
Nice....:r olleyes:
Old 01-16-2013, 05:27 PM
Project89's Avatar
[quote=LATECH;1635582][QUOTE=Project89;1635315]
Nice....:r olleyes:
it deff never ceases to amaze me what ppl will do to sell a car.
anyways the dimmer switch is the souce of my short local junkyard has one so im going to pick that up and put it in.
i pulled the battery cable and reset the ecm and ce light comes on after a few miles of driving once engine is warm so i suspect a egr code, or a knock code since the engine does ping under light and heavy acceleration.
i hate this engine gota seafoam it every 10k or so miles to knock all the carbon buildup out of the cyls to stop the pinging
it gets so bad ive even thought about rigging up a cheap water injection system to keep the carbon buildup in the cyls to a minimum
Recent Modern Electronic Engines posts with photos
1994 dodge intrepid fuel probs jerryvarnell Modern Electronic Engines 3 02-19-2012 09:28 PM
700 r4 for 1929 dodge with a 1955 dodge hemi ? rustfarmer Transmission - Rearend 4 12-15-2011 10:41 PM
Dodge Warlock Parts? ( 1980 Dodge D150 ) Silentlion_69 General Rodding Tech 6 03-24-2010 08:17 PM
2002 Dodge Intrepid - O2 sensor troubles Hammer350 Engine 2 02-13-2009 02:47 PM
2002 Dodge Intrepid - Which side is Bank 1? Hammer350 Engine 2 01-29-2009 09:37 AM
