98 f150 4.6 8.2 mpg!? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-15-2013, 09:00 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
[QUOTE=Fang16;1685265]"Change the upstreams"? Sorry, don't speak Ford. What are the upstreams? 02 sensors? Only has 1, right? Do chevy guys have to do all this "weird" stuff? Seems to me Fords are very touchy.[/Q
Every car has its quirks. If it was a 97 chevy you'd be going through fuel pumps, the csfi nightmare and dealing with the computers transmission-saving torque management system that likes to pull timing under heavy throttle.
If there was no carbon in the plenum don't expect it to make much smoke when seafoaming it.
  #17 (permalink)
Old 06-16-2013, 06:34 AM
Fang16's Avatar
Last journal entry: Project change
[quote=Valkyrie5.7;1685268]
Must have been pretty clean. Didn't make any smoke at all.
  #18 (permalink)
Old 06-16-2013, 06:47 AM
Irelands child's Avatar
Before I leave this 'going nowhere' thread, if you are using any dash board fuel mileage indicator to give you mpg that your truck has, be well aware that is called a Lie-o-meter by many on the Ford Truck Enthusiasts web site. Additionally, you will get much better information there on Ford truck operation then the myths and hearsay found here, a heavily weighted towards Chevy site: Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
Irelands child
  #19 (permalink)
Old 06-16-2013, 07:17 AM
LATECH's Avatar
Yes I meant the upstream oxygen sensors. The control the fuel trim which in turn is a fine tune to a achieve a stoichiometrically accurate mixture. 14.7 to one is ideal. A lazy 02 can stay low , reading lean, causing the mixture to go rich, wasting fuel.Plugs that are tired can cause a poor burn leaving unspent oxygen causing a mixtureto swing rich also.
Electronic Engine performance basics are the same across all makes and models. Specifics and designs vary, like fuel pressure , injector design etc.
I did see some chevy specific references, which happens here a lot, but all in all if you have any experience in electronic fuel injection, principles are relayive and one can fix anything as long as you can ID the components and you have PIDs to use for testing.
Basics like healthy spark, good fuel pressure and injector pulse, are all very basic forms of strategy that every EFI vehicle has.Also tune up parts play a very important basic role. Start with the basics.
Fact is stranger than Fiction
  #20 (permalink)
Old 06-16-2013, 07:24 AM
Fang16's Avatar
Thanks for the link. I used good old math. 144.6/18.2=7.9 My god! My 500+ HP 355 gets better mileage than that going through the 1/4! lol
  #21 (permalink)
Old 06-23-2013, 03:20 AM
Banned
this is a newish vehicle thing, most v engine have 4 o2 sensors,
to before the converter(upstream) and two after the converters (downstream)
I'd hope with 240k that all 4 where replaced at least once and the up stream should be on it's 3rd set (100k miles each time )
first thing I'd do, as you've not run it much till now. is
1) turn the key on "run" but not start it, does the orangey/yellow check engine light come on?? many people before they sell remove that bulb.
if it works move to the next.
2) either get a kit to clean your injectors or have it done. this requires the fuel pump to be disabled and they run the engine off the cleaner..
3) replace the upstream o2 senders with GOOD ones.. you get what you pay for here.
4) tune up, plugs (good ones) wires ext. fuelfilter/air filter,by now a few coils on plugs should be all but dead.. test them all one by one for good spark. if you have a buddy with alldata or hit up that ford board o how to test them..
my 4x2 97 shortbox (think light'n without the blower) 5.4 got 17 highway and 14 town with my lead foot. but it was new
you also said it sat unused for a little bit. make sure the brakes are not dragging.
wifes sport trac mpg dropped like a rock when a front hub/bearing was going freewheeled clod but once warm /hot it didn't like turning
the plugs might be might old as ford in those years had sparkplug rockets that liked to take off and take threads with them..
be ready to have to heli coil or thread cert plug holes in heads if alum.
good luck.
me gut says plugs are old because of fear of taking threads, coils are weak ,injectors need to be cleaned and o2 sensors are all but dead.
but first check the light on the dash works,
remember it's got 240k on it. it's going to need parts..
5)
  #22 (permalink)
Old 06-24-2013, 07:50 AM
Dumb question; are you sure your odometer is reading properly? If you change the height of your tire or regear the axle and dont compensate, it will be off. This would throw off your mileage calculations to some degree. Maybe you're fuel economy isn't as bad as you think it is if this was the case. I doubt this would be the sole cause of the issue however.
can you use more MPG? grandpaws 57 Hotrodding Basics 3 07-12-2011 02:17 PM
More MPG awbazar General Rodding Tech 12 03-12-2011 03:36 PM
Gm 3.1 Mpg Hippie Hotrodders' Lounge 5 04-24-2010 09:06 AM
Only 8 MPG!!!! Why? south65ss Engine 16 02-27-2007 01:48 AM
Help with MPG BillyBob1950 Engine 1 11-27-2002 09:40 PM
