98 gmc 1500 transmission noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 10:36 PM
dot 5 blinker fluid
i have a gmc 1500 truck 4 speed auto that makes a noise at low rpm ,i hear it in neutral and when i put it in gear and press the gas just a lil it will do it. other than that it shifts as it should sounds like a heat shield but i have checked all of them .what will a broken torque converter even sound like? any help please!,Bert
1996 gmc 1500 transmission problems Countryboy01 Transmission - Rearend 4 07-01-2011 03:30 PM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
Lowering a 74 GMC 1500 TiMeWaRp Suspension - Brakes - Steering 11 01-15-2008 09:26 PM
'84 Gmc 1500 P/u restor84 Engine 0 05-25-2006 09:12 PM
BB swap into '97 GMC 1500?? Dan B. Engine 1 03-07-2002 07:43 PM
