98 gmc 3500 hvac relay replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 10:54 AM
I've replaced the blower motor relay before in a 06 gmc truck, but I can't find the relay on this truck? Anyone can help locating the relay connection? I've taken the plastic cover off the blower and can't see it.
Old 01-07-2011, 03:26 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The relays are under the hood or on the left side of the instrument panel under a plastic lid.
vicrod
Old 01-07-2011, 06:02 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Some GM products in this era have the blower relay built into the blower resistor assembly.Also that year had a problem with melted connectors at the resistor.
Old 01-08-2011, 01:23 PM
vicrod
Nope. I'm looking at the factory service manual right now. The blower high speed relay is clipped to the top of the HVAC box under the dash. It should be just to the driver's side of the blower speed resistor. The relay is located here because the blower motor is inside the truck, under the dash.
HVAC system Shag0215 Engine 3 03-12-2010 10:38 AM
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
moving the hvac unit to the trunk - questions lowROLLERchevy General Rodding Tech 10 06-21-2007 10:33 PM
HVAC tech's ????? k-star Hotrodders' Lounge 8 03-16-2005 09:19 PM
possible to use HVAC system? solowookie Interior 6 11-11-2002 12:02 PM
