98 hp specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 06:37 PM
98 hp specs
ok so i have a question i have a 350 vortec 98 people are saying that with just a cam and intake with carb 400 is possible then people say no i just wanted some more opinions
Old 03-19-2012, 05:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use punctuation, pls. I read this twice wondering why in hell did you poll 98 people?
Anyway, there are about ten thousand threads on Vortec heads/engines/HP, etc. UTFSE.
Short answer is yes it is possible w/long tube headers.
Old 03-19-2012, 09:53 AM
Banned User
The engine is a 98' right?
There is a hotrod article, and most of the time i really detest hot rod magazine, but this particular article was informative dealing with the vortec 350. i would have to look for it though, or you could.
Old 03-19-2012, 09:56 AM
1971BB427's Avatar
LOL! That's exactly what I thought. But before that I read the title and wondered how he got 98 horsepower in a 350 Chevy!
Old 03-19-2012, 10:09 AM
Banned User
Until it's found, here's a good one:
http://www.popularhotrodding.com/eng...k/viewall.html
Old 03-19-2012, 10:48 AM
How do you get 98 hp out of a 350? Fall out of bed in the morning.
I thought this was going to be some sort of aircooled VW or 2stroke snowmobile/motorcycle question...*sigh*
Old 03-23-2012, 06:59 PM
ok now here is the next q what if i dont put a cam in it. till that still gimme alot of horse???
Old 03-23-2012, 07:21 PM
Wiki Edits: 31
'98 Vortech 350 is 220 HP. Camshaft upgrade will +-20-40 HP give or take
Old 03-23-2012, 08:52 PM
327NUT's Avatar
Wow, absolutely amazing!!!
Old 03-27-2012, 04:52 PM
ok i also want to know it when i take the fuel pump block off plate can i just mount a regular mechanical fuel pump to it. i mean does it have the rod in it or what will i have to do
Old 03-27-2012, 05:44 PM
1971BB427's Avatar
No, you can't mount a mechanical pump. No rod can be installed either. You're stuck with an electric fuel pump on that engine.
Old 03-27-2012, 08:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've never seen a Vortec block ('96-up) that had a drilled mechanical pump cavity. That doesn't mean there aren't any- just that I've personally not seen one.
If you have a cover over the cavity, there's a chance the machining has been done. And a possibility the block is older than '96. This doesn't really mean much- if the block has the bosses, etc. to use a roller hydraulic cam, that's the main thing, not that it was a "Vortec" block.
So, if you have a block off plate and drilled passages in the block, you will need the correct pump mounting plate and a pump push rod to use the mechanical pump. Pay attention to the material the fuel pump lobe on the cam is made of (generally it will be the same as the cam core) so you use the right material for the pump push rod.
Old 03-27-2012, 08:32 PM
1971BB427's Avatar
I've seen Vortec blocks that had a plate over what would have been a fuel pump location, but nothing machined underneath.
cam specs srx_700 Engine 3 04-19-2010 06:15 AM
l48 350 specs iluvdrt Engine 1 01-12-2004 06:18 PM
anyone have the cam specs....... mark anderson Engine 5 12-07-2003 02:00 PM
L88 cam specs Tiros Engine 1 11-03-2003 11:52 AM
73 350 sb not a 76 need specs pjsplayhouse Hotrodding Basics 2 11-01-2003 08:57 AM
