98 Lumina-diagnostic codes/for brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2006, 10:36 AM
Roddin Rob's Avatar
Hi there,
I have a problem with my ABS light coming on evry once in a while. Usually when I'm on the highway in winter weather. In town it's fine. I've already replaced the front speed sensors (2 different occasions) because I was able to test them & determine they were bad. I figure one or both of the rear two must be going as well, but of course, when I test them, everything is dry, so they check-out ok.
The first time I changed a sensor, I brought it in to the dealer, & they connected to it via diagnostic machine & identified the culprit without taking a wheel off. There must be a way to get diagnostic codes for this car that would include codes for the brake system? I went on the ALDL.COM link from one of the other posts regarding computer interfacing & did some browsing around. I can't seem to find anything for vehicles newer than 95.
Does anyone know if such technology exists out there?
RR.
Go Hard, or Go HOME!
1989 S-10 Durango 4.3L V6 TBI
1998 Lumina Sedan 3.1L V6
Old 01-14-2006, 05:50 PM
circletrack62's Avatar
Yes
Yeah, chevy has a special one. Or you can use a snap-on modis but it has to the brake soft wear. It sounds to me like it is being shorted out when it gets wet. Hope that helps.
Old 01-14-2006, 07:53 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Here are the codes for an OBD II reader:
GM
96 5.7L VIN P SFI OBDII
P1107
MAP Sensor Circuit Intermittent Low Voltage
P1111
IAT Sensor Circuit Intermittent High Voltage
P1112
IAT Sensor Circuit Intermittent Low Voltage
P1114
ECT Sensor Circuit Intermittent Low Voltage
P1115
ECT Sensor Circuit Intermittent High Voltage
P1121
TP Sensor Circuit Intermittent High Voltage
P1122
TP Sensor Circuit Intermittent Low Voltage
P1133
HO2S Insufficient Switching Bank 1 Sensor 1
P1134
HO2S Transition Time Ratio Bank 1 Sensor 1
P1153
Insufficient Switching Bank 2 Sensor 1
P1154
HO2S Transition Time Ratio Bank 2 Sensor 1
P1171
Fuel System Lean During Acceleration
P1222
Injector Control Circuit Intermittent
P1351
IC Circuit High Voltage
P1361
IC Circuit Low Voltage
P1371
DI Low Resolution Circuit
P1380
ABS DTC Rough Road Data Unstable <--------- This one I think is what you want...
P1381
Misfire Detected EBCM/PCM Data
P1415
AIR System Bank 1
P1416
AIR System Bank 2
P1441
EVAP System Flow During Non-Purge
P1508
Idle Air Control (IAC) System Low RPM
P1509
Idle Air Control (IAC) System High RPM
P1539
A/C Clutch Status Circuit High Voltage
P1545
A/C Clutch Relay Control Circuit
P1546
A/C Clutch Status Circuit Low Voltage
P1626
Theft Deterrent System Fuel Enable Circuit
P1641
Fan Control (FC) Relay 1 Control Circuit
P1642
Fan Control (FC) Relay 2 Control Circuit
P1643
Engine Speed (RPM) Output Circuit
P1652
Vehicle Speed Sensor (VSS) Output Circuit
P1653
Oil Level Lamp Control Circuit
P1661
Malfunction Indicator Lamp (MIL) Control Circuit
P1663
Oil Life Lamp Control Circuit
P1810
TFP Valve Position Switch Circuit Malfunction
P1812
Transmission Fluid Over Temperature
P1860
TCC PWM Solenoid Electrical
P1864
TCC Solenoid Circuit Electrical
P1870
Transmission Component Slipping
P1873
Torque CONV Stator Temp Switch Circuit Low
P1874
Torque CONV Stator Temp Switch Circuit High
P1886
3-2 Shift Solenoid Valve Assembly Circuit Electrical
Doc
1998 lumina problems strracer7 Suspension - Brakes - Steering 1 01-30-2004 11:15 AM
brake light 98 lumina strracer7 Electrical 0 01-23-2004 04:11 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
97 VCM in a 98 Vortec bluesman123 Engine 6 12-21-2003 11:38 AM
98 Z-28 with old style small block Deeavi Engine 1 11-02-2003 11:41 AM
