Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 98 Nissan headliner redone
Old 05-04-2010, 01:52 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
I assume you used the stuff that already had the foam bonded to it. I cut it with a good scissors.
Are you talking about trimming it after it's up on the roof? If so, you need to leave it a little long and then push it down into the rubber seal. I use a heavy putty knife with the corners ground off to do that. That will leave you with a nice clean edge.
