-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   98 Nissan headliner redone (http://www.hotrodders.com/forum/98-nissan-headliner-redone-177342.html)
PUREAUDIO 05-04-2010 10:56 AM
Heres the headliner i did for my friend. It was really bad had a bunch of tacks holding it up.....looked like stars....lol
I do have a question about cutting headliners material. What do you use to cut it i used a razor blade but it didnt cut it good. After i finished i thought about a electric knife might have been better.
Heres the pics
http://i39.photobucket.com/albums/e1...S/DSC01113.jpg
http://i39.photobucket.com/albums/e1...S/DSC01104.jpg
http://i39.photobucket.com/albums/e1...S/DSC01110.jpg
http://i39.photobucket.com/albums/e1...S/DSC01105.jpg
http://i39.photobucket.com/albums/e1...S/DSC01111.jpg
as you can see on the last pic
DanTwoLakes 05-04-2010 12:52 PM
I assume you used the stuff that already had the foam bonded to it. I cut it with a good scissors.
Are you talking about trimming it after it's up on the roof? If so, you need to leave it a little long and then push it down into the rubber seal. I use a heavy putty knife with the corners ground off to do that. That will leave you with a nice clean edge.
PUREAUDIO 05-04-2010 01:20 PM
Thanks Dan
Yes it has the foam backing, i will buy better scissors for next time. I will try the puddy knife and see if it helps the look.
