98 Nissan headliner redone - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 10:56 AM
PUREAUDIO's Avatar
Heres the headliner i did for my friend. It was really bad had a bunch of tacks holding it up.....looked like stars....lol
I do have a question about cutting headliners material. What do you use to cut it i used a razor blade but it didnt cut it good. After i finished i thought about a electric knife might have been better.
Heres the pics
as you can see on the last pic
Old 05-04-2010, 12:52 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I assume you used the stuff that already had the foam bonded to it. I cut it with a good scissors.
Are you talking about trimming it after it's up on the roof? If so, you need to leave it a little long and then push it down into the rubber seal. I use a heavy putty knife with the corners ground off to do that. That will leave you with a nice clean edge.
Old 05-04-2010, 01:20 PM
PUREAUDIO's Avatar
Thanks Dan
Yes it has the foam backing, i will buy better scissors for next time. I will try the puddy knife and see if it helps the look.
Headliner Tutorial DanTwoLakes Interior 20 07-18-2011 07:45 AM
2000 Nissan Frontier Headliner wretched ratchet Interior 7 11-14-2009 04:19 PM
Headliner help. Javelin360 Interior 10 07-24-2006 10:46 AM
ford headliner swvalcon Interior 1 03-06-2005 08:20 AM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
