98 ranger / 5R55E gear ratio error codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 06:16 AM
tnsmith10's Avatar
when will it rain???
we have this 98 ranger in the shop, that came in with a broken reverse band. the scan results from the checkout showed it had a couple gear ratio error codes stored in memory. the trans got built, and it still had the codes return... now, weve tried several things inside the trans, (a fix from a tsb, and another valve body, and re-going through the unit) without any luck., while checking the data on a road test, we noticed that from the output speed to the v.s.s., there is roughly a 4 mph difference between the 2... and the only thing weve noticed is that the tires dont match what the door tag says its supposed to have.. (taller than what it came with)
could this be the main problem like i think it is? or is there somethng else? it has no abs, so i was able to rule out abs being any or all of the cause...
crosley, chazmac, please help if u can, if im missing any info, let me know... ill fill in what i can... thx
Old 05-25-2006, 08:56 PM
airworld2's Avatar
98 ranger
5r55e tranny what are the codes,po744? 733 741 does it rev up shifting. are you using snap on scanner? most common thing that cause shift codes are solenoids and pressure control solenoid. I keep a data base of troubles I have had and fixes also been building mine since 89 books only give you some direction.
airworld2
Old 05-26-2006, 06:27 AM
tnsmith10's Avatar
i never saw the codes myself, just was told they were gear ratio error codes... were using the old red brick with the updated cartidges, and internally, and electrically everything is good (even sent it to a electric shop because the boss thought it might have been electrical after we had the unit out the second time)...
overall, my boss didnt want to listen, gave up on it, and refunded the peoples money back...
1 question though, is it possible for the truck to have the speedo calibrated? reason i ask, is because between what the scanner said it was reading for speed was 4-6 mph difference than the speedo. ( faster) since i was doing some sniffing around on a ambulance with a e4od, i stumbled across a page that mentioned a recalabrational computer for the speedo. i know its not a e4od, but with the 5r55e having basically the same sensors and setup to a degree, is it possible they put something like in the ranger? just curious because, thats the only thing that was never addressed... and yes, my boss is an idiot...
Old 05-26-2006, 09:16 PM
airworld2's Avatar
5r55e
its not uncommon for the dash speed to read different from scanner speed.I use shaffer shifter to pin point alot most always its the tranny not the computer. giving the customer the money back sometime is better than waiting to see the judge in court.
airworld2
Old 05-27-2006, 06:43 AM
tnsmith10's Avatar
if so, then how come they r the same when the wheels r off the ground? and what kind of calibration is there in the ecm to adjust for when people put different size tires than what the vehicle came with?
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
Ford Gear Ratio Stangman196700 Transmission - Rearend 4 02-17-2004 12:04 PM
chnging gear ratio RAYRAY Engine 5 10-21-2002 02:22 PM
What gear ratio should I use Maverick Transmission - Rearend 1 06-25-2002 08:40 PM
