98 s10 5spd hard to engage in gear, very early clutch engagement... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2013, 04:14 PM
1986c10's Avatar
Hi, my buddy has a 1998 chevy s10 with a 2.2l 4cylinder and a standard 5 spd transmission. According to him the thing shifted fine and clutch engaged normal prior to the temperature dropping. Now that its cold out, he said the thing was giving him some trouble so i took it for a test drive. Right off the bat, the thing would barely go into reverse. I had to really force it into reverse but it didnt grind. Then when i was letting out the clutch, the thing started moving the second i started letting out the clutch so it engages way earlier then it should, it possibly isnt completely disengaging when pushed to the floor. Sounds to be a clutch adjustment issue? Any thoughts? thanks!
Old 01-31-2013, 04:42 PM
LATECH's Avatar
The master is going bad. Cold weather caused the seals to shrink, causing a pressure lost at the top of the cylinder, where most of the wear on the bore occurs.
Cold weather does anumber on things Huh?
Fact is stranger than Fiction
Old 01-31-2013, 05:10 PM
1986c10's Avatar
That makes alot of sense, i could see that happening. So if i replaced the clutch master cylinder, are their any other parts id need to buy?
Old 01-31-2013, 05:12 PM
LATECH's Avatar
Nope. I hope the slave hangs in there untill your next clutch job.
Old 01-31-2013, 07:32 PM
1986c10's Avatar
haha, yeah who knows. I guess we'll find out. Im gonna have him order a new cylinder and i'll replace it for him. I'll post back if it fixed it. Thanks for helping out!
Transmision will not engage any gear! 72MGC Transmission - Rearend 1 01-19-2012 06:51 PM
2000 s10 ZR2 5spd clunk topdogger Transmission - Rearend 1 03-27-2011 01:05 AM
Starter tries to engage after a hard speed bump? TwistedDragon Electrical 5 03-11-2009 01:00 AM
Early GM starter engagement/noise shimmer Engine 5 01-12-2009 05:45 PM
C6 gear engagement problem? Steve-0321 Transmission - Rearend 1 09-23-2005 09:44 PM
