Could'nt find any recalls or TSB's for that problem. There has to be another issue besides the switch, something is burning out the switches. You may need to replace the blower motor resistor, check the wiring for melted wires and check and make sure all connections are good and not corroded.
Just replaced the switch in my daughters GM minivan.....The switch was melted......I think there is a lot of draw in those blower motors.
Ontario Rodders |
All of you guys are thinking the same way as I am. In the past one of both Ford and GM problems was that neither one used enough metal in their connectors. Lots of plastic , little metal. Thanks for checking.
BB |
50 amps
Another thing could be the high speed relay. This relay shunts the resistors and all of the blower motor load so the switch does not get overloaded in high speed.
Put an ammeter on the thing to see what is causing the high current. This circuit is fused at 50 amps. vicrod |
| My 74 swinger eats ballast resistors! | 73 Nova Guy | Electrical | 7 | 12-09-2007 07:42 PM |
| engine eats cam lobes | 1969chevytruck | Engine | 13 | 10-08-2005 10:57 PM |
| Snake eats Kangaroo!!!!! Pics... | Nightfire | Hotrodders' Lounge | 17 | 04-26-2005 01:23 PM |
| Saltwater eats Metal... What eats Rust ? | Dave ESPI | General Rodding Tech | 10 | 07-09-2003 11:08 PM |
| sbc350 that eats cam lobes | eblyon | Engine | 20 | 06-15-2002 10:49 AM |
