99 corvette fuel filter pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 07:10 PM
Hey guys. i am swapping a 5.7 hemi into my old coronet and have some questions that an experianced rodder may know. Street and Performance recommends using the 99 corvette fuel filter for the swap because it has a built in regulator and a return line. I have bought the filter and have it and the fuel lines installed. I purchased an in tank efi fuel pump kit from Tanks, Inc that has a Walbro 255lph GSS340 pump. I was warned by Street and Performance Friday that the hemi needs at least 50 psi to run. I started looking for info on the Walbro pump and see that it runs from 40 to 100psi. I have no idea how the pressure is adjusted. I am assuming that the Corvette fuel filter is regulating it down to a usable PSI but I don't know what that is. Can someone inform me how the system works or how it is manually adjusted?
Old 08-27-2010, 09:52 AM
Anybody? (crickets Chirping)
Old 08-27-2010, 10:02 AM
slow4dr's Avatar
The 255 lph fuel pump will produce more than enough pressure for what you're doing.
If memory serves me correct the Vette filter/regulator will set pressure at 60 psi.
I ran the quick disconnect fittings on mine and loved it. For the price you can't beat em.
Old 08-27-2010, 10:06 AM
T-bucket23's Avatar
Wiki Edits: 26
The Vette filter/regulator is supposed to do 58-60lbs. They are usually on the high side.
Chet
Old 08-27-2010, 08:49 PM
Great. I ordered the 3/8"fittings today from Jegs. With the return line being low pressure, should I bother with the fitting or just use hose clamps? The fittings run $40 for each line just at the filter! I have barbs at the tank regardless with hose clamps.
Old 08-28-2010, 09:42 AM
slow4dr's Avatar
Hose clamps will be fine. Now post some pics of the car/engine
Old 01-08-2013, 03:10 PM
Wher to get filter with AN fittings
Is the corvette filter/reg as shown in the post by slow4dr available, if so. from where
I have copied the pic here
Thanks
Old 01-09-2013, 09:14 AM
slow4dr's Avatar
Thanks
It's been a while so I am sure everybody carries them now. The one pictured is an OEM part from GM for the C5 Vettes. I don't remember the part #.
1960 corvette rochester fuel injection ratlover Engine 9 06-19-2013 08:31 AM
99 dodge 5.2L fuel pressure fast68 Engine 0 01-02-2010 01:47 PM
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
E85 compatible fuel filter, with fuel injection ripple Engine 5 05-10-2007 06:48 AM
fuel pressure accessory CORNFUSION!!! killerformula Engine 10 07-06-2004 08:02 PM
