Running a code check is a good first step. I can tell you that throttle body is too big for a mild 318, it is better suited to a highly modified 360 or a 390/408 stroker.
The fuel pressure regulator is part of the pump/filter assembly, it is located inside of the gas tank. Stock pressure is 48lbs +/-, should be plenty of pressure for your engine. I would check the position of the throttle blades, the idle air is supplied by the IAC could be a problem there. The throttle body spacer is not doing you any good, especially if you are running the stock barrel manifold, it already has massive volume. |
| Fuel Pump/ Regulator Question | 540z | Engine | 10 | 10-22-2009 10:34 PM |
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| Low fuel pressure | oldred | General Rodding Tech | 12 | 04-01-2008 11:41 AM |
| 1:1 Boost referenced fuel pressure regulator means?? | 84Z | Engine | 1 | 11-09-2004 11:54 PM |
| Fuel Pressure Variance | slomotion | Engine | 2 | 04-02-2002 01:25 PM |
