99 Dakota in need of HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2008, 07:55 PM
i have 99 Dakota 3.9 L V-6, started to change plugs and was successful in removing 5 of 6 , i discovered one was broke off and unable to get plug wrench around bottom of plug, it does have the heat shields around the plugs and have tried to remove without any luck , i have tried to scrap around plug to clear any dirt, but is seems like heat shield is enclosed around plug, any suggestions are very welcome
Old 11-05-2008, 08:13 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Broke off as in the white part, or did it twist completely off?
I'd be ripping the heat shield out of my way...
99 Tahoe - 5.7L Rebuild mrharris Engine 7 12-14-2007 06:44 AM
1990 dodge dakota 68novafan Transmission - Rearend 1 10-18-2007 07:16 PM
Dodge Panel Delivery with a 1993 Dakota Chassis 2craze Introduce Yourself 1 10-08-2007 06:43 AM
99 dakota brooksy9 Hotrodding Basics 2 11-08-2006 04:38 PM
Matching Dakota 57Chevyman Interior 2 02-22-2002 03:41 PM
