'99 Dodge pu question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2005, 11:34 AM
Jmark's Avatar
I have breakfast with an older retired guy each morning. We were talking about our trucks yesterday and he said that his '99 Dodge 3/4 ton V10 is very slow going into reverse after sitting for a week or two. He's in rehab for knee surgery and doesn't drive the truck right now. He says that when he starts it and puts it in reverse, he has to rev it a few times before it will go into gear. I don't know the exact tranny model or milage, but its not driven alot.
He called the dealer and told them what was going on because its still under warrantee and they said its normal for that to happen as the fluid drains out of the converter over the week or 2 of sitting. Is this true? If not, what are the suggestions for correcting the slow engagement into reverse?
Thanks.
Mark
Old 06-23-2005, 12:01 PM
SmallBlock_guy's Avatar
V10 info
The transmission in that vehicle is a 47RE. I am assuming that it has a trans oil cooler.
In this case it can be oil drain back. If there are no other symptoms that this is a good possibility.
Old 06-23-2005, 07:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is a common problem with mopar products for decades.
Tell him to let the truck idle in neutral ( brakes applied) while the truck warms up a bit. the tranny will fill the converter faster in neutral. See if that helps reverse apply faster
Old 06-23-2005, 10:48 PM
Jmark's Avatar
Thanks for the replies. I'm going to see him again tomorrow, as I do every day and i'll pass on the info. Just glad its nothing bad.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
Dodge fluid question 87442lover Transmission - Rearend 0 07-15-2004 06:05 PM
'33 Dodge rear end question El Raton Transmission - Rearend 3 05-11-2004 08:41 PM
Dodge pickup question newchevyman General Rodding Tech 1 02-09-2004 12:00 AM
1987 dodge 318 cam question 74huggerorange Engine 5 12-21-2003 10:54 AM
