Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 99 Durango
Thread: 99 Durango
Old 05-30-2006, 02:42 PM
SmallBlock_guy's Avatar
SmallBlock_guy SmallBlock_guy is offline
No that is a true 4 speed.
It could be a 44RE or 46RE. It all depends on the engine you have. Someone will correct me if I am wrong on the numbering. Either way it is a 4 speed. The OD off is really putting you down into 3rd. I do not think that trans is capable of 3rd LU. The easiest way to find out is do 50 MPH switch OD off it should drop down into third. Then depress the throttle slowly. It should unlock and then down shift. That trans is not capable of a locked shift either.
