99 Durango - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 06:23 PM
99 Durango
My Durango has a grinding noise in O/D if you turn off O/D the sound stops. Shifts fine just the noise in O/D. I'm thinking its the torque converter, because I believe this is a three speed with a lockup they're calling O/D?
Old 05-30-2006, 02:42 PM
SmallBlock_guy's Avatar
No that is a true 4 speed.
It could be a 44RE or 46RE. It all depends on the engine you have. Someone will correct me if I am wrong on the numbering. Either way it is a 4 speed. The OD off is really putting you down into 3rd. I do not think that trans is capable of 3rd LU. The easiest way to find out is do 50 MPH switch OD off it should drop down into third. Then depress the throttle slowly. It should unlock and then down shift. That trans is not capable of a locked shift either.
Old 05-30-2006, 07:22 PM
airworld2's Avatar
durango
46 re depends on engine size, sounds like bad od section(planets)
airworld2
Old 05-30-2006, 07:40 PM
durango trans
It has a V6. So the O/D is electrically controled similar to the 4l80E?
Old 05-31-2006, 07:21 AM
V6
If it is a V6 then it is a 42RE. That is just a three speed with a OD unit stuck on the back. I agree it sounds like a bad od unit.
99 Chevy Silverado- how to save weight? KYLEdallas Hotrodding Basics 21 11-29-2013 03:42 AM
99 s-10 lowered suspension question briansansone Suspension - Brakes - Steering 2 03-31-2006 09:33 PM
99 Escalade starting problems frankenvette Electrical 1 10-16-2005 10:12 PM
99 S-10 Engine Placment ????????? Bullit 99 General Rodding Tech 5 08-25-2003 09:08 AM
2002 Durango Vs 1990 Olds 88..i did it...... Rubberman2003 Hotrodders' Lounge 4 06-24-2003 03:09 AM
