99 escalade starting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 02:41 PM
99 escalade perodically wont start. starter is new, alternater is new and battery has good voltage. whats my problem?
Old 02-29-2012, 04:44 PM
wont start for how long, or takes along time (a few seconds) to start? The fuel pumps often have a check valve failure so each time you start you have to prime up the whole system to 50 psi, put a pressure guage on it, it should hold about 50 psi or so with the engine off.
Old 02-29-2012, 07:50 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Possibly has a problem with the security system. I had a 96 caddy that had times when it wouldn't start. I could usually pull the key out, clean it and reinsert it back in the ignition and it would start.
starting problems rdsieveke@gmail.com Engine 3 08-30-2011 09:25 PM
400 sbc starting problems jrws6 Engine 9 07-03-2006 07:18 PM
99 Escalade starting problems frankenvette Electrical 1 10-16-2005 10:12 PM
Starting problems 72elcamino Engine 9 12-12-2003 09:53 PM
Starting Problems... ?? MonsterTruck Engine 4 11-18-2003 10:45 AM
