99 f150 2wd 5.4 auto gear shift vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 08:57 AM
my 99 ford f150 has a 5.4 engine and i asume it has a c6 transmission, anyway theres a vibration when the automatic switches gears sometimes. when i checked the driveshaft its got some play in the shaft and the boot on the rear of the tranny is wet with fluid, is this a bearing problem
Old 02-25-2012, 05:11 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Your truck most likely has 4R70W
The vibration could be a u joint.
A bearing would make noise and be pretty constant, and the frequency would increase with speed.
the leak is a seal, if it is at the output of the trans, it may need a tail shaft bushing.
TH350 Auto Shift Woes juiced66malibu Transmission - Rearend 5 12-01-2007 08:58 PM
Auto shift lever adjustment Mertz Transmission - Rearend 5 09-17-2007 01:57 PM
gear shift problem in c6 auto wiseguy50 Transmission - Rearend 8 06-14-2007 07:23 AM
changeover from auto to std. shift wheel-7 Transmission - Rearend 3 10-25-2003 05:23 PM
