99 f150 door locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2003, 12:35 AM
99 f150 door locks
I have a 1999 f-150. Both driver and passanger power door locks have stopped working using the button and the keyless entry. The locks will seem to try and actuate but rearly fully actuate. I have replaced all three lock relays and the problem still exists. I have considered changing the lock actuaters in each door. However it seems odd that both would have started acting up at the exact same time. Does anyone have any suggestions?
Old 08-03-2003, 08:02 PM
The actuators usually go out completely if they are not working properly. Your linkage and lock mechanism may need luricating. If you are in a high humidity region, it will do wonders on that stuff. Use lithium grease to lubricate. If that doesn't help the problem, it is beyond my knowledge. As long as you can hear the actuators trying to work, they should be working properly.
Old 01-28-2005, 09:36 PM
99 ford door locks
did you ever figure out what was going on with your door locks ?mine are doing the same thing . thanks mxp@accessbee.com
Old 01-28-2005, 11:17 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Most Ford actuators have a rubber boot around the actuator shaft. That boot gets soaked with oil from the grease put on the shaft at the factory and starts to break down and gets clogged up in the shaft. Pull the door panel and if the boot is denigrating remove it and lube the shaft with wd40. You may want to disconnect the actuator shaft from the lock mechanism and then operate the lock button to see whether it is a actuator problem or a lock mechanism problem, but while your in there lube the latch anyway. If you remove the actuator from the latch you will possibly break the plastic retainer clip and will need to get a new one at the dealer.
Old 04-10-2005, 01:16 AM
door locks
just got my new locks in today the old ones tried to lock but just did not have enough power changed the actulaters and they work like new ones 4/9/05
