99 Jimmy Idle problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2005, 06:25 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
1999 GMC Jimmy 4.3 (W) 4L60E 3.42 geared 4WD.
Problem: Engine starts normally, idles normally, then begins a slight stumble varying the idle rpm's, but seemingly not out of the ordinary, if transmission is shifted into gear (any) it has NO power and stumbles with a very noticable roughness and acts like there is a backfire condition. This is "slightly" eliminated by rapidly feathering the throttle.
Temporary Solution: I start the engine, and raise the engine to around 1500 or 2000 for roughly 30 seconds, then let the engine idle and shift into gear and drive normally.
The wife has told of a power loss around 45 mph, but I have driven the Jimmy more than her and I have not experienced it as of yet.
I have no real test equipment to speak of and am more than prepared to use the multimeter to check the IAC, TPS, O2 sensor, and the likes, I just have little information in the Haynes manual to go on to check these.
I have heard there is a major problem with the fuel injection lines possibly splitting and the poppet balls sticking, but the symptoms do not seem to point to these.
The PCM shows no codes with a OBD II reading Actron scanner.
Old 10-05-2005, 07:33 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Like you said the fuel injection set up on this engine is known for problems. usually it causes a hard misfire. Have you checked fuel pressure, fuel pumps go bad quite often in these also. Fuel pressure should be at 60-66 psi with key on engine off. How long does these symptoms stay or do they never go away?
This sounds like maybe you have some injector poppet's that are stuck open and you are just clearing out the unspent fuel. Sometimes they (poppet valves) will start to work after the engine warms up.
Do you live in California by chance or does the truck have Cali emission system on it? if it does they (GM) has a recall on the injection set up.
Hope this helps, I will try to help as much as I can.
Steve
Old 10-06-2005, 06:08 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Steve
I don't live in CA, Pennsylvania, but the Jimmy has the RPO code NC1 indicating: EMISSION SYSTEM, CALIFORNIA, LEV .
I'll have to check with the local GM dealer on this before spending any $$$.
I have tried to check initially the IAC valve operation or lack thereof by disconnecting it.
With the engine warm, disconnecting the IAC connector & starting the engine it actually seemed to run better, I have waited for it to cool down to check it again cold, I will go out right now to check it and type the results. . . . .
I didn't allow it to cool to a fresh start situation, but disconnected the IAC wiring, and drove it 1 mile and stopped, the engine acted as before (normal because it was still warm), when I stopped and shifted into park the engine went to a high idle.
I opened the hood to reconnect the wiring to the valve and drove it back home, it had a slight stumble when taking off from the dead stop, but acted normally as before.
I will let it fully cool and try again later as the problem only presents itsself then.
I will also check on the CA emissions recall too. does anyone have the recall campaign number?
Old 10-06-2005, 08:31 AM
1931 steve's Avatar
Wiki Edits: 4
Recall # 99066F
I read the campaign wrong, from what I get from the campaign is the vehicle needs to be registered in California. Sorry
It does list a injector cleaner GM part #12345104 It is stated that this is the ONLY cleaner that has any effect on the poppet valve deposits.
If you would like I can fax you these TSB. Sorry AllData will not let me copy
and paste there info, too much to retype. Send me a PM with your fax #
Steve
Old 10-06-2005, 05:08 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Only one problem with a fax right now, I just put a new printer/fax/copier/card reader in service here, and that is one of the things I still have yet to take the time to figure out.
I'll work on it and drop the PM to you.
Does anyplace else post TSB's for free?
I did a cold start with the IAC disconnected, and there was little change? EXCEPT for the fact I seemed to have a little more power? along with the high idle.
I was only able to set one trouble code, and that was unintentional as I knew I did it when it happened.
I was unable to check the injector harness with the limited noid light set I have, but I do not believe there is a problem with any of the injectors NOT working.
I have to make two service appointments for a two vehicles here and they are at two different dealers, and will make sure to ask if there is anything they can do for me as to what I should look for on the Jimmy. I will make sure to hit up the salesman to get any freebie work done that I can, he owes me one already anyway.
Also, should it start & run that easily with the TPS connector disconnected too?
__________________________________________________ ________________
I am researching the TSB's on the NHSTA website.
Old 10-06-2005, 05:55 PM
1931 steve's Avatar
Wiki Edits: 4
Not sure if anyone does.
Yes, it should make no difference at start up with the TPS unplugged. It will set a light on.
Do you have a fuel pressure tester. If so leave it hooked up for the cold start, and see if by just turning the key to the run position if the fuel pressure holds steady or if it drops off, if it drops off you have a sticking poppet injector.
I hope we are on the right track by assuming that it is a fuel related problem.
Steve
Old 01-22-2006, 09:02 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I have not completely found this problem's cause OR the solution.
BUT, I have only put a few hundred miles on the Jimmy since then, I had to R&R the heater core because of the wonderful effects of GM's Dex-Cool clogging up the cooling system and specifically the heater core.
Backflushing the entire cooling system and in particular different portions of it did nothing more than remove the immediate loose stuff. I went up to a full chemical flush, which did little because of the vague directions on the bottle, and eventually repeated for the recommended PROLONGED timeframe, which broke a bunch more crud loose.
I ended up saving myself $1200 at the dealer and removed the entire dash to get the heater core out of the vehicle to chemically clean it and to make sure it wasn't going to leak because this was going to cost me $140 if it did.
I sent several gallons of water under pressure in both directions through the core, and treated it to several different chemicals, fully flushing the core in between treatments. I was finally satisfied with the results and re-installed it in the vehicle.
I found an agricultural chemical sprayer screen type filter that would accept fittings large enough to be installed into the heater hoses, and routed the hoses through the filter, but not through the cleaned heater core, and then a full dose of cooling system CLEANER for a whole week (which is still within the recommended timeframe. I pulled the screen out of the filter after each drive and cool-down cycle and was surprised at the amount of junk I removed from it. I removed what resembled small rust FLAKES and chunks of sediment that couldn't be good for anything at all.
When the filter stopped collecting this crud, I finally went through the task of flushing the cooling system, then I backflushed, and I flushed individual portions of the entire system until I found nothing coming out but water.
I removed as much water as I could, replaced all hoses and plugs, and included the filter as a full-time part of the system then with the information that the system held a total of 12 quarts I added 6.75 quarts for a slightly more than 50% solution for the conditions it would be up against here in the area where I live, and then added water to make up the difference.
The main difference in the system now is that I got rid of every trace of the problematic orange Dex-Cool coolant, and added a properly mixed solution of green ethylene-glycol coolant.
I have since handed the keys over to the wife and she has put several hundred Miles on it and has no complaints about the heating capabilities inside the vehicle.
I still haven't completely found the problem with the stumble off idle yet. . .
Old 01-22-2006, 09:44 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I have since then, installed a fuel pressure gauge, and found that the key-on-engine-off reading was at the lower end of the recommended pressure range.
The engine running at idle reading was low, and the rev-throttle low end reading was below the low end of the recommended range.
I am also replacing the original factory installed 78,000+ miles ago, cap/ rotor/ wires/ & plugs, and as long as I'm at it fuel pressure regulator, removing and cleaning the throttle body as it's VERY dirty inside and out.
I have seen what to look for when I remove the throttle body, to determine if anything with pressurized fuel is leaking under the upper intake manifold, and have the gasket set to make those determinations and repairs if necessary, the only things I will have not replaced by the end of today are the fuel pump and the 6 injectors.
I have also gotten the recommendation to pull the linear EGR valve and chech to make sure it isn't plugged, I have been told that it will be more than obvious if it is working because there will be signs of the valve's movement.
Old 01-23-2006, 06:39 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Cap, rotor, plugs, and wires are changed. The plugs were the only things that weren't factory original. I have never seen build-up on the cap and rotor posts like these had.
The whole thing took over 4 hours, with the plug on cylinder three being over 1 hour in itsself because of what was in it's way.
The throttle body cleaned up quickly with a little paint thinner to loosen the crud and a wire brush on my dremel.
There is a difference but there is still the fuel pressure regulator to work on changing.
While I had the thottle body off the upper manifold, I noticed there looked to be some fuel washed areas in the lower manifold, so while I have the manifold halves apart to change the regulator, I will also try and check the injectors for sticking poppet valves. This may have to wait until this weekend.
I have gotten OBD II codes P0171 (bank 1 lean condition) and P0172 (bank 2 lean condition) twice now, the second time just hours before the ingition tune-up. This thing was using gas at a rate of 11-12 miles per gallon while I was doing the majority of the cooling system cleaning, and isn't much better now. I also had a P0300 (random/ multiple cylinder misfire detected) but I had wires 3 and 5 crossed, I know, something I should have checked more accurately before starting it.
Old 02-05-2006, 08:01 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I changed the left and right bank oxygen sensors this afternoon as well as the fuel filter.
The recommended mileage for the sensors is 60,000, and it has 78,000 on the clock.
The filter will be cut apart tomorrow to look inside, it still flowed freely but a change for $9 couldn't hurt anything.
I will change the after catalytic converter oxygen sensor when I get that one, they had to order it from another store.
Next will be the fuel pressure regulator, snow with a 12 MPH wind and 26 degrees said no today, the wind and rain yesterday said the same thing.
Old 02-06-2006, 06:50 AM
1931 steve's Avatar
Wiki Edits: 4
If you are at the low end of the fuel pressure readings, just replace the fuel pump assembly, They are pricey at about $300.00 + give or take. I would suggest that you buy a Delphi or Delco if you can, I just replaced the pump assembly last week in my wifes Jimmy. My cost at a discount was $275.00 for the Delphi unit. Did I miss the reason why you are replacing the FP regulator?
Steve
Old 02-07-2006, 09:40 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The regulator is a must if there is a fuel washed area around it, which is only evident after the upper manifold is removed, which I haven't done yet.
And since I have the upper off to check, I already have the regulator.
I don't like the price of the stock fuel pump, and the warranty period is the same as the others. A Master E3992M at the local parts place is $264.44, but I have only checked 1 of the 5 parts places in town.
I used a Master pump when the Caravan needed a new one after our local refinery put out some bad gas, they offered to pay for repairs, but my luck- I had already changed mine and their offer was not grandfathered to repairs already done without receipts from a garage they had authorized. I ran it for 2 years without problem (from the fuel system- anyway).
Old 02-07-2006, 09:23 PM
1931 steve's Avatar
Wiki Edits: 4
[QUOTE=M&M CUSTOM]The regulator is a must if there is a fuel washed area around it, which is only evident after the upper manifold is removed, which I haven't done yet.
I must have missed what you said about the fuel wash. if that is the case yes replace the FP regulator. When you order the pump assembly, make sure you tell them it a 2 door or 4 door model, it does make a difference.
Steve
Old 02-08-2006, 06:03 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
[QUOTE=1931 steve]
Steve
The only ways to check the lower manifold for fuel wash are small snake flashlight and a dental mirror, or remove the upper manifold from what I can see, I couldn't see much at all when I had the throttle body off to clean it.
I seen that there was a difference between the pumps for the 2 & 4 door models BUT there is also a notation to replace some section of wiring harness as *highly recommended* from more than one source. What section of harness is this referring to?
I haven't yet gone to get the third oxygen sensor yet, the Jimmy runs better with a slightly noticable gain in mileage- but the off idle engine cold stumble is there at much less of a strength.
I also noticed that when coming to a stop, the idle does not go down as low as it should (1200 rpm's).
This is really stumping me as I don't have a multi-meter to check anything with at the moment.
Absolutely NO SES codes as of yet either.
Old 02-12-2006, 08:57 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
As of yesterday:
Third oxygen sensor changed, with a little more mileage back to where it should be.
Fuel pressure regulator changed, took 3 hours, and there was a section of the rear portion of the lower manifold that was fuel washed, as long as it was out I cleaned the upper manifold, and removed built up gunk from the ends of the injector nozzles.
I used just a quarter tank of gas through it last night, and am at the point in miles where it was down around the halfway mark so the mileage has increased dramatically.
I still have that pesky stumble at/ and off idle, and I noticed that when I removed the throttle body that the IAC valve didn't look like it had been seating, If I could test this (still haven't found a good enough multimeter to replace my old one) I could replace or rule this out. It DOES however go through the motions of resetting itsself, I disconnected it and drove a ¼ mile, connected it and drove it again and it brought the idle back down to where it should be.
Next step for this is either buy the software and cables for reading OBD II, or take it somewhere and have tham charge me too much.
Help! Jeep Idle Air Control 68NovaSS Engine 1 09-16-2005 04:17 AM
Performance cam with a 2 corner idle Holley DP 650 Mad Maggot Engine 15 08-02-2005 06:04 AM
Pontiac 250 idle problem youngbw Engine 1 07-07-2005 07:30 PM
Stumble off idle in park, carb or ignition problem Dubz Engine 3 05-18-2004 10:29 PM
Q jet won't idle! Trav Engine 6 11-13-2003 06:44 PM
