99 mustang with 408 windsor, which trans to install? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2013, 09:11 PM
hey guys im new to the forms and ive surfed a few of them, i have to say u guys seem to know ur stuff..
before i ask my qustion ill let u know what im buliding. i have a 99 mustang coupe with a 351w bord and stroked to a 408 with 510 hp about the same tq with a carbed setup. no tranny, 7.5 diif with 410 ford racing gears and a posi.
i know the rear end not the best buts it's a buget bulid till i figure everything out.
which brings me here.
i have the motor in the car and i must say its a perfect fit.
my qustion:
im about to start with the tranny and i have a few dreams but not enough cash. what im trying to do is keep the oem speedo and abs. ive read a few fourms on this site with alot of good info but not what i need to know. im looking at a 95 mustang gt auto tranny aode and im woudering if this set up will work for what i want to do. in other words plug and play?
i also have a aod non e out of a 89 crown vic cable driven speedo. im wondering if theres a way to hook that up to an eletric speedo vss?
i would like to save the $300 on the aode and use the aod.
i know theres alot of other trannys i shoud use or could use but like i said budget bulid. i do plan to upgrade but i rather make a small mistake then a real expesive mistake.
Old 03-23-2013, 09:36 AM
LATECH's Avatar
I would say the AOD with a manual valve body kit makes the most sense.JMO
Fact is stranger than Fiction
393 Windsor vs 408 Windsor rcm800 Engine 7 06-27-2012 12:16 PM
1994 mustang building 408 stroker for car.need help Luke 200 Introduce Yourself 1 09-24-2010 03:21 PM
68 Mustang with 351 Windsor ladyblu Introduce Yourself 1 11-13-2007 04:18 PM
408 W in a 2000 mustang firestone Engine 1 10-04-2004 06:50 AM
408 windsor comet boy Engine 3 07-30-2004 08:24 AM
