Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 99 ranger tranny rebuild - what special tools are needed?
Old 02-18-2013, 08:16 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
99 should be a 5455 e with a 4.0 there not a bad unit to build make sure you replace the servos on the side of the case i aways use the zc cover and pistons on both the center support is known for wear use a superior shift kit do not use a transgo kit in this unit get a large ratio pressure regulator valve they make thicker steel clutch plates to get the clearances tighter becareful cleaning the valve body it has many clips that will fall out also use a a external trans cooler
