Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 99 Tahoe trans swap
Old 07-29-2012, 10:34 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by boomguy View Post
I have a 99 tahoe with a 4l60e, broke the sun shell... I have an 02 yukon with a 5.3 in it that was rolled... can I swap the trans and transfer case to the 99, I dont know much about the 4l60, th350, 400 and 700r i do, but was told it has a removable bell.. any help would be appreciated..
Does your 1999 have a 5.7 engine? That would be a non LS series engine. The 5.3 is a LS series.
The 2002 4L60e has a deeper bell housing, different input shaft design. Converter is different for the 5.3 LS engine crankshaft and new design input shaft.
it is not a direct bolt in swap if you have an early design engine
