99 Tahoe trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 10:16 AM
99 Tahoe trans swap
I have a 99 tahoe with a 4l60e, broke the sun shell... I have an 02 yukon with a 5.3 in it that was rolled... can I swap the trans and transfer case to the 99, I dont know much about the 4l60, th350, 400 and 700r i do, but was told it has a removable bell.. any help would be appreciated..
Old 07-29-2012, 10:34 AM
Crosley's Avatar
Wiki Edits: 1659
Does your 1999 have a 5.7 engine? That would be a non LS series engine. The 5.3 is a LS series.
The 2002 4L60e has a deeper bell housing, different input shaft design. Converter is different for the 5.3 LS engine crankshaft and new design input shaft.
it is not a direct bolt in swap if you have an early design engine
Old 07-29-2012, 10:51 AM
dont sound good
yes it has a 5.7.... so guess it cant be swapped...
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
2000 Tahoe W/4L60E trans problem crackrbaby1 Transmission - Rearend 0 04-21-2009 08:12 PM
1995 Tahoe 5.7 TBI to Vortec Swap LiftMeUp Engine 2 12-24-2006 09:23 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
trans swap rizzo59 Transmission - Rearend 1 12-19-2003 04:21 PM
