the oem dist gears are known to fail and theres a lot of torque being applied to the dist gear from the oil pump when the engine is cold and thats where the wear is from especially if you use anything thicker than the 5-30 recommended , I lost mine at 100K , I replaced the whole thing cam , gear and timing set , I was told its the chain getting loose combined with the roller cam that causes the cam to snap back and forth on the gear face from the roller pressures and when the oil is cold , if you got 240, 000 miles out of it I consider that extremely lucky ( alot of hiway miles I presume ) , the gear is made from sintered metal then mellonized ( hardening process) and when it breaks it will get ground up in the oil pump and might stick the bypass open , when Mine went I pulled the pan and replaced the pump too ( it had wear onthe lower plate andthe inner faces from the grindings , most of the crud was caught in the filter so I replaced the pump as a precaution as its in front of the filter I still had 40 Psi at hot idle ) if your experiancing loss of oil pressure ( at hotidle ) I would then look at the bearings. I pulled a main bearing and found no wear or damage . this is why a good filter is worth the money ! one thing if you replace the gear/cam . is to flush the distributor galley with alot of oil to help flush out any peices ( I poured about a gallon thru there and abunch of powder like stuf came out , and I now run a magnet on the botom of the pan and on the filter to help catch any remains .
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Vortec 350 balencer question | carguy332000 | Engine | 0 | 10-09-2008 04:43 PM |
| turbo 350 question | 86sdub | Transmission - Rearend | 8 | 04-01-2008 09:52 AM |
| Chevy 350 engine swap – motor mount question | 78transam | Engine | 4 | 06-04-2007 05:57 PM |
| 305 vs. 350 question | DesertPanel | General Rodding Tech | 4 | 10-16-2003 08:19 PM |
