!999 Grand Prix Heater Core - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2006, 05:29 PM
Trucknut's Avatar
Hi Guys!
I have this friend that wants me to remove, repair and replace the heater core in his 1999 Pontiac Grand Prix. I'm from the old school when heater cores weren't that much of an issue to repair/replace. These newer cars are more compilicated. I'm not short on tools, but could use some help with deciding if I want to get into this.
Thanks in advance for all the help I know I'll get
Chris
P.S. Maybe we should have a cooling/heating system section for questions?
Old 03-16-2006, 06:12 PM
97Z28's Avatar
NTI Grad.
1. drain cooling system
2. remove drain hose from the bottom of the heater case
3. remove panelse from under the dash and steering column trip cover. also remove center console.
4. remove the heater outlet duct and glove box
5. remove heater core cover
Thats directly out of a haynes manual for an 88 - 99 Grand Prix. And from the pictures im looking at the heater core is right in the middle of the dash twards the rear of the passenger compartment. Doesnt look too bad to me. hope this helped
Old 03-16-2006, 06:56 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
97,that makes it sound easy. . Its not a fun job, I would think twice if you have never done one on a late model car.
Steve
Old 03-16-2006, 07:02 PM
97Z28's Avatar
NTI Grad.
lol... the haynes manual is good for that. they make it look like a 15 minute job, then 4 hours later your just getting the part removed that you needed. i wasnt sayin it WAS easy, just LOOKED easy. guess i shoulda clarified.
i did a core on a cavalier, and that wasnt too easy because the stupid thing was mounted up against the firewall between the blower motor and firewall.
Anyway, like Steve said, if you've never done a late model car i would try to steer away from it unless you have a whole weekend to mess around with it that way you can take your time.
well, Good luck if you decide to do it!
-Matt
Old 03-17-2006, 03:00 AM
Trucknut's Avatar
re: heater core
Thanks for your help......everyone! I think I'll stay out of this. I have plenty of truck work to do wthout getting into a posible three or four day mess. I appeciate your advice and, by the way, you're right about Haynes manuals.
What ever happened to Motor's manuals?
Heater Core flow direction garretthes Engine 12 09-26-2004 08:09 PM
heater core Brian Morency Engine 6 08-27-2004 12:55 PM
Ever install a heater core in a chevy Van? tm454 Hotrodders' Lounge 6 04-04-2004 01:31 PM
heater core box sealing? montea General Rodding Tech 3 02-07-2004 12:50 AM
Jumping the heater core hose...is it ok Adrenaline_Fiend Engine 8 06-02-2003 04:00 AM
