9bolt to 10 bolt parts swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2012, 07:50 AM
Very new to this stuff so please bear with me. I have an MGB with a 3.5 rover engine, around 230HP, car weight is approximately 2200LBS, my rear end is a cut down S10 limited slip and I really need a positive traction unit. I recently purchased a 9 bolt out of an 86 Camero with positive traction. Am I correct that both the 10 bolt S10 and the 9 Bolt are 7.75 inch diameter ring gears, if so will the positive traction carrier interchange?
Old 01-21-2012, 08:35 AM
Last journal entry: update
Sorry. The 10-bolt started at 7.5", then later upgraded to 7.625". You can put a 7.625" set-up in the 7.5, but that Borg-Warner Australian 7.75" 9-bolt has NO interchange with the GM 10-bolt.
The 9-bolt isn't worth fussing over, toss it in the trash.
Back to your 10-bolt. Pop the cover, remove the cross-shaft pin with a 6-point 8-mm ( 12-point WILL round off the head of the pin ) and slide an axle out to count splines. Early is 26, late is 28.
Also, the 10-bolt uses 2 different offsets, depending on the gear ratio. 2-series includes the 3.08:1, while 3-series includes 4.10:1.
Once you know which series and which spline count, then you can search for whatever differential you like.
The 10-bolt has far more after support, since it was used in Camaros from '82-'02. That 9-bolt was '86-'89 TPI Camaros only. And unlike the 10-bolt, the 9-bolt was never used in any other GM vehicles.
Old 01-22-2012, 10:13 AM
Thanks so good to know not to waste any more time with it. Another question will the disk brake parts on the 9 bolt fit on the 10 s10 rear end? I would like to utilize the disk in place of the drum from the truck.
Old 01-24-2012, 03:04 PM
Project89's Avatar
were are u located id like to buy that 9 bolt rear from u for my iroc.
if u are to far from me and u want to sell it dont trash it, post it for sale on thirdgen.org and somone with a 3rdgen f-body will deff buy it. the 9 bolt is a decent cheap upgrade from the stock 7.5/7.625 rear, for guys on a budget
do u happen to know what gear ratio is in it as well ?
Old 01-25-2012, 05:28 AM
Love to sell
I am in located in Jacksonville Florida how can I get in touch with you ?
Old 01-25-2012, 09:24 PM
Project89's Avatar
never mind im across the country in utah im sure shipping would very expensive on the rear.
sign up on thirdgen.org and post it for sale in the classifieds on there if u want to sell it lots of the 3rd gen guys look for the 9 bolt rears
Old 01-25-2012, 09:33 PM
RippinRon's Avatar
No, the disc and drum housing ends are different and the brackets wont work. Thirdgen.org is a good source of information.
9 bolt posi parts 87 irocz28 Transmission - Rearend 1 09-22-2011 09:16 AM
Swap out Parts McSS86 Engine 1 08-31-2010 11:06 PM
chevy 10 bolt 8.5" parts source? 18camaro Transmission - Rearend 2 01-27-2008 06:44 PM
12 bolt for 10 bolt swap, driveshaft length? Cousin_Joe Transmission - Rearend 4 11-08-2007 07:50 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
