9in ford rear what years? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2002, 12:06 PM
Post 9in ford rear what years?
I have currie 9in rear housing with 31 spline axles, not having much luck finding 1970,s cars. what are some newer cars from which I can find stump I need? gears not important. need list of 80,s or 90,s donnor vhicles. any help greatly appreciated. jack
Old 09-24-2002, 12:40 PM
SJFast's Avatar
Post
http://hiqties.hypermart.net/9inch.html
Old 09-24-2002, 04:33 PM
Post
thanks Mr Fast, but they only give me a list of vehicles from the 60,s and 70,s, you see thats the problem Im having trouble finding anything that old I need a list of newer vehicles which have 9in I can use. thanks I really appreciate the help.
Old 09-24-2002, 05:32 PM
Talking
[quote]Originally posted by jcknmin:
Im having trouble finding anything that old I need a list of newer vehicles which have 9in I can use. thanks I really appreciate the help.[/QB]<hr></blockquote>
The reason he did not list cars from the late 80's and 90's is .........Ford did not make any in those later years. Ford started the 9" in 1957. The last one was in 1984 in a Pickup I believe. 1979 for Ford passenger cars.
31 spline center sections came in High Horse cars and some trucks. Lincolns too. Beter off to buy new not abused. You can change 28 to 31 fairly easy.
DEUCE ROADSTER.........
Old 09-24-2002, 05:43 PM
Post
thanks deuce i appreciate the reply.
Old 09-24-2002, 05:52 PM
roys63's Avatar
Post
Alot of ford PUs used the 31spline axels, when looking in the bone yards look at center of the axel flange the 28 are flat and most have 2 dimples, 31s are dished in.This is were the tire bolts on.And all the 60s T Birds and most SWs,XLs Happy Hunting
Old 09-25-2002, 05:10 AM
Post
thanks roy, that was one piece of info i was hopeing to learn, telling the difference between 28 and 31 , without pulling the stump, thanks.
Old 09-25-2002, 07:28 PM
Post
Most rears will have a tag bolted to it. About the size of a Army dog tag. The tag will tell you if it is 28 or 31.
If you are not worried about the gear, just buy a Aluminum center section and a Detroit Locker, add your choice of gears and GO!
Old 09-25-2002, 11:14 PM
Post
thanks Deuce, Im familiar with the tags but have never noticed axle type codes or if I did I didnt know what it was. I have currie polished alumnium center section. Im building a 33 speedstar coupe,frame is by alloway. I will check on price of new stump. I take it you are a 32 guy,so am I. over the years i have built about 12 32s. just sold, at louisville nsra, 32 3win which I built last winter and still have 32 vicky which I drive to runs. Thanks, and keep on roddin. Jack
Old 09-29-2002, 05:43 PM
DJM DJM is offline
New Member
Post
I have to disagree with one of the answers submitted. No disrespect intended but, when looking a axles the 31 spline is flat while the 28 spline is recessed. I have not had much trouble finding center sections, open or posi, in either 8 or 9inch. Try a local race shop.
Old 09-30-2002, 02:06 PM
roys63's Avatar
Post
Yes you are right! i just checked this , Its been a while since i have looked for a 9"31 i use to break one just about every other week in my 64 XL 4 speed 406.Sorry about that!
Old 09-30-2002, 05:07 PM
Post
thanks DJM and roy I appreciate the help.
Old 10-06-2002, 03:45 PM
woodz428's Avatar
Troll Hunter
Post
While the description of the axle ends was correct(flat for 31's and inset for the 28's) in the truck rearends that isn't always the case, for some reason the truck axles,28 & 31, are both flat and need to be pulled for positive ID.I think it may have been to cut production costs.
Old 10-06-2002, 04:17 PM
dmorris1200's Avatar
doesn't play well with others
Post
Woodz, I'm afraid the real reason is that Ford just never wanted anything to make sense. Never did and I don't think they ever will.
But I still luv em.
BUILT FORD TOUGH
Old 10-07-2002, 04:49 PM
New Member
Post
You want to look at 4x4 rear ends for 31 spline axels. In the mid 70's
