9inch fluid change - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2005, 10:37 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
9inch fluid change
Well i was out changing the fluid in my 79 F250 4x4 axles and i thought.. maybe i should change the differential fluid in my cougar. Well its a 70 cougar with a ford 9inch rear end. Obviously its not like the truck's diff. (no cover to unbolt) MY question is how do i change the fluid? I hope i don't have to take out the gear assembly. I know how to fill it (unbolt plug)
Thanks for the help guys
bill
Old 04-08-2005, 01:22 AM
aka Duke of URL
If it doesn't have a drain plug in the bottom of the housing (and most late models didn't) you will either have to loosen/remove the carrier, use a suction gun via the fill hole or drill and tap a NPT thread for a drain plug.
toploader horrible after fluid change 65fbmustang Transmission - Rearend 4 11-21-2004 08:22 PM
When to use Silicone Brake Fluid jpd37 Suspension - Brakes - Steering 4 04-17-2003 06:02 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
