Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1985 1/2 ton pickup
Old 02-09-2012, 09:21 PM
matt167 matt167 is online now
Wiki Edits: 31
2wd to 2wd or 4x4 to 4x4, automatics should work if there both 700-R4's. SM-465 4spd from an '85 will not correctly fit a '88-'98 truck if it's a M/T. 1500's got the old Getrag 5spd that year, the 3/4 and 1 tons still got the SM-465 for 1989 and 1990 but the shifter and output are diffrent than the earlier transmissions, and of course, the trans crossmembers are diffrent
