?????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2003, 01:25 PM
smokin's Avatar
New Member
Question 305 HO heads on a 350 ??????????
OK. now does any body know what kind of horse power I will be making with 14014416 ho 305 heads that have been ported and polished on top of a 350 std bore with flat tops and a 280/480 cam with a 4 barrel carb and headers
Old 10-20-2003, 02:36 PM
Jmark's Avatar
Atleast 100!
Old 10-20-2003, 05:42 PM
mikeweyman's Avatar
Last journal entry: 2 years later
hi dude,I have a set of these heads and i asked about the same question ,what I learned is as follows.
These heads will produce in the range of about 10.5 to 1 compression ,you must be carefull of detonation. adding about 10% race fuel,you can keep this from happening. you can fatten up or thin out the head gasket enough to get you back in the 10.5 to one range.
there was no response as to horsepower, but i'm only guessing that low end torque would be incredible , but would pi$$ the bed at maybe 4,500 rpm as per air suffocation.it would starve for flow.
from reading quite a bit about G.M. heads , you can't port them out big enough to be effective . using vortec or even common 882 castings (2.02/1.65)if done,maybe more,will flow much better than any 305 head.
maybe this combo would be ideal for say a 4 wheel drive truck, lots of ball$ to pull loads, maybe a 4 speed.
hey you real experts out there , let me know if any of my information is flawed, as i have only been learning this for a while myself. mike
Old 10-20-2003, 05:43 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Please read the Guidelines for posting.
All your questions can be found in the Knowledge Base.
Luv the smell of NITRO in the morning.
