A4LD Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2004, 12:16 PM
A4LD Problems
I have an '89 Mustang LX ,2.3L ,with an A4LD transmission. My problem is the trans doesn't downshift after a hard acceleration. It acts as if it has been put in neutral. If the engine it shut off and restarted the trans will shift again until you try to accelerate quickly. It seems to work fine during a graduall acceleration or deceleration. The manual I have suggests the TV cable but their illustrations do not show my particular setup. As far as I know this is still the factory setup. And fluid and filter have been changed. The filter wasn't too dirty and the fluid wasn't burn't, not much sludge found in the pan either. I need some kind of a clue what to check on this. Thanks!
Old 02-13-2004, 12:41 AM
abstruse dutch uncle
From what i have read on this transmission, this is a fairly common problem, although the shutting it off and turning it back on kind of threw me. It is not computer controlled in any way, and has no electronic parts, so it's not like rebooting or anything. It must be that shutting it off just drops the RPMs enough that the parts start to mesh again (so I guess it is kind of like a reboot ).
Your transmission likely has a busted "sprag". I have no idea exactly what that is, but it sounds clutchpack related, and means you need a rebuild, likely with some new hardparts.
If your TV cable and brackets are all original, and the book does not show your setup, find the common denominator of the different setups.. like, full and complete cable retraction at wide open throttle (like on the GM's). or find another book.
But this "sprag" thing is likely your problem. AAMCO does a free testdrive and diagnosis related to said testdrive, at most of their shops, or at least they did a couple of years ago. Any diagnosis beyond the testdrive is going to cost you some greenbacks though.
