A4LD Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2011, 09:14 PM
chevynut1's Avatar
A4LD Transmission
I have looked thru posts on this transmission and didn't find one that seemed to fit.
I have a 86 Ranger with the 2.3l and a4ld trans. When starting out in 1st when cold it shifts OK, but when it warms up you have to let off the gas to get it to shift. Also once you get into 3rd in shifts up and back (3rd to 4th and back). Any ideas what the problem could be? one more question, How much trouble would it be to install the M5R1 manual tranny? Thanks for any help you can give.
A4LD Ford Trans. AmericanPackMule Transmission - Rearend 1 03-27-2009 05:37 AM
A4LD rebuild has gone bad slingslingbinks Transmission - Rearend 3 09-03-2004 09:03 AM
A4LD Problems 57Ford Transmission - Rearend 1 02-13-2004 01:41 AM
slipping A4LD Mikebox Transmission - Rearend 3 01-06-2004 02:23 PM
A4LD question BstMech Transmission - Rearend 1 12-12-2003 06:30 AM
