-   -   ? about 700R4 clutch packs (http://www.hotrodders.com/forum/about-700r4-clutch-packs-155611.html)
Overdriv 03-25-2009 10:27 AM
To the techs and anyone that have used the Raybestos Z-Pak, do you think this clutch pack would handle WOT shifts into 4th gear?
What about the 2-4 band, is the wide carbon fiber band best?
Any suggestions and discussions are welcome.
I'm trying to build the ultimate 700R4 to put in my S10 pro-street truck.
The engine is a 406SBC, 375-400 hp, 425-450 Lb ft torque. 9" ford, 4.56 rear. 31X14X15 Hoosier slicks for the strip and 31X18.5X15 MT Sportsmans for the street.
My ride.
richard stewart 3rd 03-25-2009 10:56 AM
Hi Mike,
Very nice job on the truck, realy looks good.
Rich
PS Don't know anything about the Raybestos clutches.
SSedan64 03-25-2009 11:10 AM
Z-Packs are good & from what I've been reading the Carbon band is the best available.
Overdriv 03-25-2009 11:44 AM
Do you think they would survive in a drag race environment? Even though the truck is mostly run on the street, we want to race it a few times a year.
Crosley 03-25-2009 08:20 PM
the red ALto brand band works well too.
the key here is the drum area the band applies on MUST be flat. Many used drums are cupped some.
I'd suggest a new drum. The remachined drums are flat , but material was removed to make them flat and I think the drum can warp again easier since it is thinner
Overdriv 03-25-2009 10:11 PM
I will plan on a new drum there. Thanks Crosley. Do you have any experience with the Z-Pak mentioned in my initial post?
SSedan64 03-26-2009 11:05 AM
Good thread on Band & some clutch material.>
http://www.turbobuick.com/forums/tra...alto-band.html
Overdriv 03-26-2009 12:21 PM
Real good discussion, full of good stuff, thanks man!
Crosley 03-26-2009 08:06 PM
i've used the Z-pak for a couple of years. Good performance so far.
Overdriv 03-26-2009 10:25 PM
That's good to hear. I think I will plan to use the Z-Pak for 3-4 clutch. What do you guys think about me using the blue clutches in the other clutch packs?
