? about 700R4 clutch packs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 11:27 AM
Overdriv's Avatar
To the techs and anyone that have used the Raybestos Z-Pak, do you think this clutch pack would handle WOT shifts into 4th gear?
What about the 2-4 band, is the wide carbon fiber band best?
Any suggestions and discussions are welcome.
I'm trying to build the ultimate 700R4 to put in my S10 pro-street truck.
The engine is a 406SBC, 375-400 hp, 425-450 Lb ft torque. 9" ford, 4.56 rear. 31X14X15 Hoosier slicks for the strip and 31X18.5X15 MT Sportsmans for the street.
My ride.
Old 03-25-2009, 11:56 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Mike,
Very nice job on the truck, realy looks good.
Rich
PS Don't know anything about the Raybestos clutches.
Old 03-25-2009, 12:10 PM
SSedan64's Avatar
Z-Packs are good & from what I've been reading the Carbon band is the best available.
Old 03-25-2009, 12:44 PM
Overdriv's Avatar
Do you think they would survive in a drag race environment? Even though the truck is mostly run on the street, we want to race it a few times a year.
Old 03-25-2009, 09:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the red ALto brand band works well too.
the key here is the drum area the band applies on MUST be flat. Many used drums are cupped some.
I'd suggest a new drum. The remachined drums are flat , but material was removed to make them flat and I think the drum can warp again easier since it is thinner
Old 03-25-2009, 11:11 PM
Overdriv's Avatar
I will plan on a new drum there. Thanks Crosley. Do you have any experience with the Z-Pak mentioned in my initial post?
Old 03-26-2009, 12:05 PM
SSedan64's Avatar
Good thread on Band & some clutch material.>
http://www.turbobuick.com/forums/tra...alto-band.html
Old 03-26-2009, 01:21 PM
Overdriv's Avatar
Real good discussion, full of good stuff, thanks man!
Old 03-26-2009, 09:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
i've used the Z-pak for a couple of years. Good performance so far.
Old 03-26-2009, 11:25 PM
Overdriv's Avatar
That's good to hear. I think I will plan to use the Z-Pak for 3-4 clutch. What do you guys think about me using the blue clutches in the other clutch packs?
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 09:31 AM
Th400 clutch packs 68novafan Transmission - Rearend 1 10-02-2006 05:06 PM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 04:21 PM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 06:56 AM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 11:23 AM
